How to make visitors use HTTPS when they use the domain “domain.org” or “www.domain.org”? If they don’t add “https://” in the beginning, they will use HTTP.
no error
none
no error
none
Make a file in htdocs called .htaccess, and put this in there.
RewriteEngine on
If you use CloudFlare, there is a setting for that in SSL/TLS.
It worked, THANKS!
