linda01
#1
lindacom.infinityfreeapp.com
failed ftp upload
I am able to ftp to the root directory using the curl command $ curl -u username:password -T test.txt ftp://ftpupload.net/
How do I ftp to a directory e.g htdocs. I tried ftp://ftpupload.net/htdocs and ftp://ftpupload.net/ /htdocs but this does not work.
Can you try to use a ftp client like filezilla
linda01
#3
Thanks but I would like to use curl in the gitbash commandline as I am learning how it works.
Admin
#4
Interesting, I had no idea that it was possible to do FTP with cURL. I’ve used cURL quite a bit, but only with HTTP.
Last time I did FTP on the command line, I used the lftp
program for that.
Although, I do suppose you could try:
curl -u username:password -T test.txt ftp://ftpupload.net/htdocs/
The trailing slash may be important, it can be the difference between uploading the file TO the htdocs folder or AS the htdocs folder entry.
system
Closed
#5
