I couldn’t generate a CSR from Infinityfree.net. How can I generate this Certificate sign-in request(CSR) for my ''comodo" SSL certificate?
Your support is highly appreciated!
Why pay when you can get it for free?
You can generate a CSR from the control panel. Simply login to the hosting account control panel, go to SSL/TLS, select your domain and click the “Generate Key/CSR” button. Then, fill in ALL the fields there (you can enter “NA” in the fields that are not relevant) and click Generate.
As for the web server type, that should probably be something like “Apache”, “PEM”, “separate domain certificate and chain”, “Linux” or something like that. I don’t know which formats are shown there and what will provide you with the right format.
