How to hide "/index.php" in homepage URL?
My website URL is: http://ack.fanclub.rocks/
What I’m seeing is: http://ack.fanclub.rocks/index.php
Additional information: When you first visit the URL, it looks fine. But when you click the “Translate” button it adds “/index.php” to the URL.
Hi
delete only this code in white (And tell me if that’s what you wanted)
Thanks, that will probably work. Unfortunately I’m getting this error now that I deleted the index.php and uploaded the new one:
“Connection failed: No such file or directory”
You could only edit it with monstaFTP :slight_smile:
Please check your database configuration, database hostname, etc.
https://infinityfree.net/support/common-mysql-errors/
Thanks, you are right I should have edited in Monsta. The problem was I forgot to change the database credentials after I had changed them for testing on XAMPP on my pc.
