hi i want to keep my subdomain test.test.com to redirect to IP x.x.x.x
when I ping test.test.com it should reply x.x.x.x
is it possible here?
Well, you didn’t do a good job explaining, but if your main site is on Cloudflare, you can point a sub-domain or that domain elsewhere.
Using/Setting up Cloudflare Guide:
Cloudflare sub-domain guide:
Problem solved using cname thanks.
system
Closed
#5
