How to login to localhost
Hello, how do I access localhost, I have tried everything and can not.
Can you install Elgg, if so how!
Thanks for the help!
You’re already on localhost. Localhost is the computer you’re currently working on. You can access it by typing localhost in your browser window. And seeing how you’re able to do something with your localhost (by using a browser to post this message), I take it you already accessed your own computer successfully?
Joking aside, can you please clarify what exactly you are trying to do and what localhost has to do with that? Which service on localhost are you trying to access?
