infinity free failing redirect to control panel how could i resolve this error,connection time out error?
Probably your internet connection because it works alright for me.
huh!,the internet is okay, as you can see am able to reply and this has been going on for a week now
But you said that your connection times out. to open control panel, go to “https://app.infinityfree.net/accounts” then click on your active account on which you want to open control panel, then click on control panel.
Does this happen to you on all browsers? If you have Chrome you can follow these guidelines about the err connection timed out error.
I also recommend you to flush your DNS cache and also renew your IP address:
- Open the Command Prompt as Administrator
- There run these commands one by one:
ipconfig /flushdns
ipconfig /registerdns
ipconfig /release
ipconfig /renew
netsh winsock reset
