123321
1
messageforhumanity.org
I want to redirect the domain to this : Message for Humanity
But only HTTP traffic is redirected. How do I do same for HTTPS
I see your HTTPS domain hasn’t been configured correctly?
Btw, how did you setup redirection for your HTTP domain? Just do it again for your HTTPS domain.
123321
3
I used the redirect all (310) which is seen in the cPanel under “redirects”
How do I configure my HTTPS
Your website doesn’t work under HTTPS traffic.
123321
5
Why not. How do I fix that
123321
7
Will cloudflare do the SSL for me if I set it up through cPanel
Set it up manually, Enabling through cpanel will ruin it.
123321
9
Because all of my traffic is redirected my SSL wont verify
Admin
10
Redirecting your website only affects website traffic on that specific URL. Subdomains and any other services are completely unaffected.
But do please note that your hosting account has the domain name messageforhumanity.org, but you’re requesting SSL for messageforhumanity.org.uk. They are different domains.
11
Hi, thanks for spotting, think thats the problem
system
Closed
12
