I want to remove my SSL certificate from cPanel and use Cloudflare SSL. How to delete SSL from cPanel.
You must go to your cPanel, then to your SSL/TLS section, select your domain and press “Delete Certificate” next to it.
but that did not work
Could you please explain what exactly the problem is and what you’re trying to do?
