I need to reset my SSL Infinityfree certificate, but I don’t know how to do it?
I need help.
I need help.
You can’t strictly “reset” an uploaded Certificate, you can only change it. So you would have to get another Certificate and upload that.
And how would I have to obtain it and again? And put it on the same page?
You can use the Free SSL Tool provided by InfinityFree to get an SSL Cert, and then you would have to upload it via the CPanel.
And does it only change the certificate when generating a new SSL or the key too?
No, it will give a new private key and a new certificate. You don’t need to worry about the CSR.
ok i will try thank you very much
