CodeIgniter is a powerful PHP framework with a very small footprint, built for developers who need a simple and elegant toolkit to create full-featured web applications.
– CodeIgniter
Creating a full PHP
website yourself is hard, and that’s why there are PHP Frameworks
A PHP framework is a platform for creating PHP web applications. It contains libraries with pre-packaged functions and classes and, more often than not, elements for software design pattern realization.
Laravel is a popular PHP Framework
, but you should have shell access to the server to get the most out of it, and you don’t have shell access on InfinityFree.
CodeIgniter on the other hand, doesn’t require shell access at all. So in my opinion, CodeIgniter is the best PHP Frakework to use with InfinityFree. In this post, I will explain how to install CodeIgniter 4
on your InfinityFree account.
How to install CodeIgniter 4 on InfinityFree
Step 1 - Download CodeIgniter 4
Source Code (zip)
and extract the zip. -
Step 2 - Extract the zip to your project folder root. Say
D:\Dev
Step 3 - Rename the folder
framework-4.0.4
to your project name. Example:MyProject
Step 4 - Go inside the
MyProject
Folder, and openapp\Config\App.php
in a text editor, and change$baseUrl
to your domain (or subdomain) with a trailing slash. -
Step 5 - CodeIgniter 4 requires you to “point” the server to the
public
folder. To do this, create a.htaccess
file in the project root, ie.MyProject
, and add the following into it:
RewriteRule (.*) /public/$1 [QSA,L]
Step 6 - Finally, upload everything inside
MyProject
to yourhtdocs
folder viaFTP
How It Looks
When you go to your website, you will see something like this:
To customize your website, see the CodeIgniter Docs
Example Site
My website, hosted with InfinityFree is completely made with CodeIgniter - https://jnote.ml
Avoiding getting suspended
CodeIgniter can sometimes use a lot of resources if your code is bad. To protect agaainst this, I recommend you to use a Local PHP Development Server on your computer for testing and only upload to infinityfree when you are done testing.
To do this, you can run the following command in a terminal after cd
ing to your project folder:
php spark serve
and access http://localhost:8080
on your computer.
