How to uninstall wordpress
antimatter.cool is always fine. the problem is antimatter.cool/wp-admin. this page is not showing
RewriteEngine On
RewriteBase /
RewriteRule ^index.php$ - [L]
RewriteRule ./index.php [L]
https://antimatter.cool/wp-login.php also does not work
Did you encounter any issue while reinstalling wordpress?
No. I didn’t. I deleted the old one. Then installed the new one… maybe I can try do it again?
Sure, just make sure the url is w/o https.
Thanks…yes, I remembered I choosed https, yet I didnt install SSL. guess thats the problem?
its working now. so if I want to use https …what should I do next? looks like SSL is not free?
Thank you so much for the help .
Very likely. Once you have successfully installed wordpress you will know the answer…
Welcome, you can get free SSL cert from https://app.infinityfree.net/ssls.
Anyway, I can see you are still on cloudflare.
Thank you so much. It’s working now. It was the problem of SSL and I choose https. THank you again for the solution
Welcome
