using the example in the link you showed
and i’m still getting the same problem
going to plantas.epizy.com/test leads me to a 404 error page
i honestly don’t think the problem is in the code, everything seems to be typed correctly and makes sense, but somehow doesn’t work
i could be wrong tough
@wackyblackie
None of them seem to work, in any way
Just tried 3 different solutions from there, all of them lead to a 404 page
That’s why i don’t think the problem is in the code
I might be doing something else wrong
Also i’ve tried this earlier in the day and it did seem to work sometimes
Just now it doesn’t anymore
1.Write your code in any code editor (VSC)
2.Create a file in Infinity Free as example (don’t include the html version)
3.Paste the Code in the File
4.Your Page is Live
I checked your account and I think I see why your previous code gave a 404 error: the code is placed in a file called htaccess, but it should be called .htaccess. The dot at the start is really important, and the file needs to be named exactly that or it won’t be picked up.
