Where are you trying to upload the .htaccess file too? Note that it must be in the /htdocs folder, and the .htaccess file in the root folder should not be edited.
Thanks.
Don’t worry, I’m already throwing it there, but after installing it is deleted back, is there a solution for this? I tried others like filezilla, winscp but it didn’t work.
What do you mean? You cannot edit the .htaccess file in the root folder, nor can you replace it. You must create and upload a new one to the /htdocs directory. Also, make sure it is not larger than 10KB (If it is larger than that, there are probably rules in there that would be more efficient if not used in .htaccess)
Thanks.
I’m already uploading the htaccess file to the /htdocs directory, I’m not creating a file or anything, and the problem is not whether I install the htaccess or not.
@jackc24, not that almost all free hosts have the same limits, as they are powered by the same company. Can you please share your .htaccess file here?
Thanks.
When sharing your .htaccess file, please type:
Code here
