estou utilizando o wowonder no diretório Script todavia ao utilizar o .htaccess necessário para o funcionamento este por sua vez é excluído e mesmo tentando criar totalmente do zero apresenta o mesmo erro.
obs: realizei testes e o htaccess está no seu devido local
I am using the wowonder in the Script directory however when using the .htaccess necessary for the operation this in turn is excluded and even trying to create totally from scratch it presents the same error.
Note: I performed tests and the htaccess is in place
I already translated the topic; please check the translation out. I also deleted the duplicated topic, even though I had to split it to a separate topic, but I had to clean the forum up.
I’m sorry, but I don’t understand your message. I understand that there is some kind of issue with the .htaccess file, but I don’t understand exactly what the issue is.
