Hello everyone,
I am having a problem with uploading HTML to my website. When I upload the HTML, I only see the code on the website and the HTML is not rendered. Here are a few things that I have checked and confirmed:
The extension of the file (.html) is correct.
The name of the file is “index.html”.
The problem is not likely to be in the code, as when I upload it to a website where I can preview HTML, it works there.
I know this may be a very simple question, but I have been trying for a few hours and nothing seems to work. Any ideas on what I could be doing wrong?
Thank you for your help!
Please fill out the template when requesting support, by including your website URL so we can verify whether it displays for us or not.
Have you verified that the file is placed in the correct folder (htdocs/
if it’s the domain you signed up with, domain/htdocs/
otherwise)?
Can you also attach a screenshot to show what you mean?
Hi! The url should be: lucasdld.epizy.com
So for me it shows the code(see screenshot)
, but it should show it rendered, which is just a square on an empty page.
And yes, i did place it in the correct folder
Okay, so this is very strange… it seems that your file does not contain your actual HTML code, but something wrapping that code as text (you can notice by viewing the source code by doing Ctrl + U).
Did you save your file from a text editor such as Word? I could only replicate this effect there, and if so, when saving to HTML there it will not save the code that you’re writing as HTML code, but as text and it will keep the text editor’s formatting of it.
Try editing your index.html file from Online File Manager and replacing everything with the code the contents of which you want displayed (so this):
<!DOCTYPE html>
<html>
<head>
<title>Vierkant</title>
<style>
.square {
width: 100px;
height: 100px;
background-color: blue;
</style>
</head>
<body>
<div class="square"></div>
</body>
</html>
Oxy
April 29, 2023, 3:55pm
5
the website shows exactly what the code tells it to !
this is a source from your site
Click here
<html>
<head>
<meta content="text/html; charset=UTF-8" http-equiv="content-type">
</head>
<body class="doc-content" style="background-color:#ffffff;padding:72pt 72pt 72pt 72pt;max-width:451.4pt">
<p style="padding:0;margin:0;color:#000000;font-size:11pt;font-family:"Arial";line-height:1.15;orphans:2;widows:2;text-align:left">
<span style="color:#000000;font-weight:400;text-decoration:none;vertical-align:baseline;font-size:11pt;font-family:"Arial";font-style:normal"><!DOCTYPE html></span>
</p>
<span style="color:#000000;font-weight:400;text-decoration:none;vertical-align:baseline;font-size:11pt;font-family:"Arial";font-style:normal"><html></span>
</p>
<span style="color:#000000;font-weight:400;text-decoration:none;vertical-align:baseline;font-size:11pt;font-family:"Arial";font-style:normal"><head></span>
</p>
<span style="color:#000000;font-weight:400;text-decoration:none;vertical-align:baseline;font-size:11pt;font-family:"Arial";font-style:normal"> <title>Vierkant</title></span>
</p>
<span style="color:#000000;font-weight:400;text-decoration:none;vertical-align:baseline;font-size:11pt;font-family:"Arial";font-style:normal"> <style></span>
</p>
<span style="color:#000000;font-weight:400;text-decoration:none;vertical-align:baseline;font-size:11pt;font-family:"Arial";font-style:normal"> .square {</span>
</p>
<span style="color:#000000;font-weight:400;text-decoration:none;vertical-align:baseline;font-size:11pt;font-family:"Arial";font-style:normal"> width: 100px;</span>
</p>
<span style="color:#000000;font-weight:400;text-decoration:none;vertical-align:baseline;font-size:11pt;font-family:"Arial";font-style:normal"> height: 100px;</span>
</p>
<span style="color:#000000;font-weight:400;text-decoration:none;vertical-align:baseline;font-size:11pt;font-family:"Arial";font-style:normal"> background-color: blue;</span>
</p>
<span style="color:#000000;font-weight:400;text-decoration:none;vertical-align:baseline;font-size:11pt;font-family:"Arial";font-style:normal"> }</span>
</p>
<span style="color:#000000;font-weight:400;text-decoration:none;vertical-align:baseline;font-size:11pt;font-family:"Arial";font-style:normal"> </style></span>
</p>
<span style="color:#000000;font-weight:400;text-decoration:none;vertical-align:baseline;font-size:11pt;font-family:"Arial";font-style:normal"></head></span>
</p>
<span style="color:#000000;font-weight:400;text-decoration:none;vertical-align:baseline;font-size:11pt;font-family:"Arial";font-style:normal"><body></span>
</p>
<span style="color:#000000;font-weight:400;text-decoration:none;vertical-align:baseline;font-size:11pt;font-family:"Arial";font-style:normal"> <div class="square"></div></span>
</p>
<span style="color:#000000;font-weight:400;text-decoration:none;vertical-align:baseline;font-size:11pt;font-family:"Arial";font-style:normal"></body></span>
</p>
<span style="color:#000000;font-weight:400;text-decoration:none;vertical-align:baseline;font-size:11pt;font-family:"Arial";font-style:normal"></html></span>
</p>
<p style="padding:0;margin:0;color:#000000;font-size:11pt;font-family:"Arial";line-height:1.15;orphans:2;widows:2;height:11pt;text-align:left">
<span style="color:#000000;font-weight:400;text-decoration:none;vertical-align:baseline;font-size:11pt;font-family:"Arial";font-style:normal"></span>
</p>
</p>
</body>
</html>
except that the doctype declaration is missing
you also have the class “doc-content” and you don’t have any CSS defined anywhere
and hundreds of repetitions for the CSS style for <p><span>
I very much doubt these are manual. Word applies those automatically, and I bet other rich text editors do too.
Alright, so i tried writing the code directly to the online file manager and now it works.
I guess i just have to use a different text editor then.
Thanks for the help!
I use notepad++ (free opensource) for my website and have never looked back
system
Closed
May 6, 2023, 7:18pm
9
