my website display a part of html not all of it
if i use xamp i see all the webpage but here i see only a part of it
it should look like this
store6.up-00.com/2017-04/14932994696491.jpg
but on infinityfree it look like this
store6.up-00.com/2017-04/14932997515731.jpg
The page returns a 500 Internal Server Error status code, which suggests the underlying PHP code is crashing. Can you try to enable error reporting and see what’s going on? You can do that through your control panel.
