Error Message: Fatal error : require_once(): Failed opening required ‘/home/vol6_8/epizy.com/epiz_28288701/htdocs/Sources/src/vendor.php’ (include_path=‘.:/usr/share/pear/’) in /home/vol6_8/epizy.com/epiz_28288701/htdocs/Sources/Load.php(2272) : eval()'d code on line 76
I was using SMF through Softaculous while this error occured. I had just installed some themes. This message appears when I type in my site url on the browser. I cannot access admin panel either. Please help. Thank you.
It looks OK, but also like Vanilla Forums, not SMF.
I’m willing to try and help you, but that’s hard to do if you remove the site before giving us a chance to look at it.
If you’ve got a working Vanilla Forums installation and are happy with it, then all is good. If you’d rather use SMF, please retry the installation and reply here if you still have any issues.
The error message refers to a file Sources/src/vendor.php, but no such file exists in your site. This is strange.
Looking at the information of the Potato theme, it’s made for SMF 2.1. Your site is using SMF 2.0. Softaculous probably doesn’t offer SMF 2.1 yet because it hasn’t been formally been released.
So maybe you can try upgrading your site to the pre-release build of SMF 2.1, or maybe use a theme that works with SMF 2.0, at least until SMF 2.1 is fully released.
