It would help a lot if you could explain a bit more about why you say it doesn’t work. What do you see when you try to use this code? Can you share the URL of your website so we can check if we see the same issue?
ERR_TOO_MANY_REDIRECTS is error page on browser.And I found tool and it counted 18 redirects.
@elonmusk
Elon Musk? Here?
If you are using CloudFlare you must enable the setting from there, called Always use HTTPS.
I also assume you have cleared your browser’s cache, huh?
@ChrisPAR said: @elonmusk
Elon Musk? Here?
I am using CloudFlare SSL from Admin panel.
Also thank you for replaying.
@UnknownLolz
I cant give you the url beacuse I cant risck any page down.
@Joo_Nath said:
How come Elon Musk didn’t know how to activate SSL when he can send things to space?
He has so much important things to do, that he cannot remember what to do with SSL.
Try revert your .htaccess to its first state, then use Always Use HTTPS like @ChrisPAR stated above.
Exactly, if you use CloudFlare then the .htaccess method is just a waste of time.
Just use the free tool already provided by CloudFlare, just one click, its much easier !
