Username epiz_30008090
I am downloaded vanillaforum from following link.
https://open.vanillaforums.com/download/
I am tried to upload it to my website. It facing some trouble while uploading. Can you guide me to the steps to do that, If you’re used it before.
I haven’t any prior experience with creating a forum. So If you can please help me to create it by teaching steps to do that.
KangJL
October 27, 2021, 4:19pm
#5
Even if you managed to upload, it is unlikely to work
U need premium hosting…
When trying to install software on InfinityFree (either by hand or through Softaculous), you may see an error message like this:
Could not make the query numbered : 16
MySQL Error No : 1071
MySQL Error : Specified key was too long; max key length is 1000 bytes
This error is caused by the fact that the script in question requires the use of the InnoDB storage engine for MySQL.
However, the InnoDB storage engine is not supported on InfinityFree. You can only creat…
The best way to do it and faster is to download FileZilla for your OS from here.
Then you should login to your FTP and then extract your VanillaForums .zip file and drag the .zip contents from your computer to your website FTP.
Then which community can be added to infinityfree without expenses
YT_Xaos
October 28, 2021, 12:52pm
#8
You can download forums with Softaculous in the cPanel.
Thanks dude , it’s working
system
Closed
November 8, 2021, 4:42pm
#11
