I am not able to generate sitemap xml its showing error
Website URL
https://magic-e-poetry.infinityfreeapp.com
(please specify the URL of the site on which you are experiencing the problem)
404 Not Foud
(The page you were looking for could not be found)
This is message is showing when I open Wordpress and in that I used yoast SEO and in that when I try to view XML sitemap its always showing error
What issue?
Both your site and sitemap.xml can be reached.
I suppose you placed your sitemap in https://magic-e-poetry.infinityfreeapp.com/sitemap.xml
And this is what I got.
Can you please provide more info?
when i try view my site map from yoast SEO plugins I am not able to see it
its showing error
I am not able to view it
I have done every things?
is this enough info?
i have also tried generating sitemap from xml-sitemap but when itry to place it in cpanel - filemanager-public html
but there is no public HTML where i can place my generated XML sitemap
[quote=“Magicepoetry, post:4, topic:78602, full:true”]
its showing error
when i try to view it from here
its showing this error
The best way is to contact plugin developer directly
That’s because the directory here isn’t called public_html, but htdocs. It is either the main htdocs directory, or if this isn’t the domain you signed up with, yourdomain/htdocs.
It seems however that you shouldn’t generate an XML sitemap yourself, as Yoast won’t recognise these. This article might help:
(If needed for section 3, you’re on an Apache server.)
