& also i have added cloudflare name servers to my domain register as it was needed for ssl. Now, please tell me what to do next
@Xceleron said:
what is the name of mx record is it mx.epizy.com that i need to add in mx record of cloudflare
Yes and the priority is 10
@UnknownLolz said:
@Xceleron said:
what is the name of mx record is it mx.epizy.com that i need to add in mx record of cloudflareYes and the priority is 10
yes, as you suggested i wen to DNS settings & in the 1st column i have selected mx record then its asking name. what is the name.
@Xceleron said:
The name should be your domain name or you can simply just put " @ " not your domain
Also the meaning of “@” is your domain
@Xceleron said:
& may i know the mail server is it mx.epizy.com & the automatic ttl
The mail server is mx.epizy.com
And the ttl is when you want this DNS record to be published.
You can set it to 2 minutes so that the record will be live in 2 minutes or you can just set it to automatic.
TTL means time to live BTW
@UnknownLolz said:
@Xceleron said:
& may i know the mail server is it mx.epizy.com & the automatic ttlThe mail server is mx.epizy.com
Thank you so much unknownLolz. it worked as you have suggested.
TTL means time to live BTWThank you so much unknownLolz. it worked as you have suggested.
Your welcome and always glad to help! ?
This topic needs to be split/merged cause it’s look like that our comments here are off-topic.
Good call, you’re right, this topic has gotten quite out of hand.
- The Pingdom posts have been removed. A separate topic for that was already created: https://forum.infinityfree.com/discussion/4020/please-help-with-my-website-optimization
- The fake staff account has been moved here: https://forum.infinityfree.com/discussion/4029/fake-byethost-staff-on-this-forum
Just as a reminder: this topic is about @Xceleron being unable to receive email.
