I cant Connect FTP
epiz_28695600
Response: ‎‪220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
Response: ‎‪220-You are user number 3078 of 6900 allowed.
Response: ‎‪220-Local time is now 04:23. Server port: 21.
Response: ‎‪220-This is a private system - No anonymous login
Response: ‎‪220 You will be disconnected after 60 seconds of inactivity.
Command: ‎‪AUTH TLS
Response: ‎‪234 AUTH TLS OK.
Status: Initializing TLS…
Status: Verifying certificate…
Command: ‎‪USER epiz_28695600
Response: ‎‪331 User epiz_28695600 OK. Password required
Command: ‎‪PASS *******
Response: ‎‪530 Login authentication failed
Status: Login data contains non-ASCII characters and server might not be UTF-8 aware. Trying local charset.
Error: Failed to convert command to 8 bit charset
Response: ‎‪421 Timeout - try typing a little faster next time
Error: GnuTLS error -110 in gnutls_record_recv: The TLS connection was non-properly terminated.
Status: Server did not properly shut down TLS connection
Error: Could not read from socket: ECONNABORTED - Connection aborted
Error: Disconnected from server
Do you read?
Change your password to use only “English” letters!
Avoid using non-ASCII characters in usernames and passwords
It is best to copy the FTP password from the Client Area
and then to paste into the FTP client
instead of writing by hand and that way you type something like this
Also in FileZilla - under the site manager → charset - click auto detect.
