Ok i tried but gives me CNAME record is not pointing
You need to wait a while until the records propagate. If youâre using other nameservers, you may also need to add an A record for the non-www domain that points to the IP of your Main Domain that can be get from this pre-configured DigWebInterface, overwriting abcd1234.epizy.com
with your Main Domain available on the Control Panel and clicking on âDigâ, and then point the CNAME record for www
to your domain, in order for your website to work again.
Well the challenge one is not ready but other one is so i need to wait:)
Hello its me,
Ä° searched dns from what is my dns and its open for many countries but not for infilityfree?
Try to change the nameservers to our ones and add the CNAME records required for the validation from the âCNAME Recordsâ section of the Control Panel.
When i change to custom freenom dns will get deleted
Then wait maximum 24 hours, and try to refresh the DNS records again from the same page of the Client Area.
kk
I waited and refreshed it was ready but i cant enter my site?(I maked ssl cert and did managed
to add my domain )
Note:The time is 2.10 for me (serious)
Ss:
Try to do this:
Well i already changed nameservers but i can see cert.
I checked your domain but it doesnât appear to have any nameservers right now. Can you please check with Freenom to make sure your domain name is still active?
Yes it is(I changed to biaders.cf but its working fine.)because gq was not worked after i changed nameservers
As you can see here, the nameservers of Freenom donât return anything for biaders.gq.
An example of how it should look is your own domain biaders.cf, which does point to the byet.org nameservers:
If your domain name shows as active on Freenomâs end and is configured to point to our nameservers, then this is probably an issue at Freenom. If so, only Freenom can solve this, so please contact them.
