My website URL is: hfworldtest.gq
What I’m seeing is:
I’m using this software:zerossl
Additional information:why the error is showing??? plese admin help:sob:
What I’m seeing is:
The Let’s Encrypt bot used on ZeroSSL and SSLForFree is blocked by a security system that, when visiting your website, loads firstly aes.js and then converts the AES code to then create a cookie with the name of __test and hexadecimal value with an expiry date of 2038 when visited on a browser; if not it throws errors. You can use your own nameservers, or use CloudFlare, either from the cPanel integration or from dash.cloudflare.com.
