When I make any changes, they are only visible in https://enhanseo.com version which is non-www. This changes are not visible when I go to https://www.enhanseo.com version. Also I have only one sitemap file which is seen in non-www version: enhanseo(dot)com/sitemap(dot)xml . The www version shows a completely different file. See www(dot)enhanseo(dot)com/sitemap(dot)xml (I can’t put more than 2 links because I’m a new user)
Also when I make changes to my custom(dot)css file, no changes are visible in either version of the website.
I can’t find where this 2nd version stems from inside the file manager.
Also, caching is not a problem for this because I’m using incognito mode.
Solved. I had to chang the stylesheet’s file name as well as the link rel thing in the header of my website. Then it started showing changes.
Glad you got it working. In the future, please mark this as “Hosting Support” as you need help.
But you are also using Cloudflare, which also caches things.
