To summarize, the host adding the ?i=1 is a security feature. The second url is instructions on modifying the .htaccess to automatically remove that.
My question is, will there be any issues with this? I have it implemented and haven seen any issues yet. Will this be a problem?
I don’t see anywhere in on that page where it mentions the “?i=” addition that infinityfree adds. Also, I did mention that the solution I mentioned does work just fine. No bad redirects it seems.
The guide just tells you how to set up Cloudflare, not everything that Cloudflare will do for you. If you follow the guide, Cloudflare will serve your site’s files, not InfinityFree, so the js file will not be sent.
Web sitelerini kötü amaçlı botlara karşı korumak için sistemimizin gerekli bir parçası halindedir. Sorun yaratmadiğı için url adresinizden değişim yapmaz.
translated by the moderator
It is a necessary part of our system to protect websites against malicious bots. Since it does not cause problems, it does not change your url address.
