I need some help
Ummm… I was using SMF Forums on my link. (http://cf-vcmp.rf.gd).
The problem I’m facing is the website doesn’t connect to the database. Maybe, because recently my cPanel, FTP and MySQL passwords were changed. So, I thought maybe changing it from the Softaculous part would rectify my error… But I get this error.
And also to not that all the details I’m entering are correct, I just don’t know abt the SB Password if it’s correct or not. Tell me abt that, do I need to use my MySQL password as DB password?
are you Trying to install SMF? because it is already installed but with database error.
To see what’s the actual error, enable display errors:
it shows this…
please enable display errors.
It still shows the same thing.
would you mind to paste hete content of Settings.php? that’s where database information are ? (with censoring password)
    <?php
 * Simple Machines Forum (SMF)
 * @package SMF
 * @author Simple Machines http://www.simplemachines.org
 * @copyright 2011 Simple Machines
 * @license http://www.simplemachines.org/about/smf/license.php BSD
 * @version 2.0
########## Maintenance ##########
# Note: If $maintenance is set to 2, the forum will be unusable!  Change it to 0 to fix it.
$maintenance = 0;		# Set to 1 to enable Maintenance Mode, 2 to make the forum untouchable. (you'll have to make it 0 again manually!)
$mtitle = 'Maintenance Mode';		# Title for the Maintenance Mode message.
$mmessage = 'Okay faithful users...we\'re attempting to restore an older backup of the database...news will be posted once we\'re back!';		# Description of why the forum is in maintenance mode.
########## Forum Info ##########
$mbname = 'Crazy Fighters';		# The name of your forum.
$language = 'english';		# The default language file set for the forum.
$boardurl = 'http://cf-vcmp.rf.gd';		# URL to your forum's folder. (without the trailing /!)
$webmaster_email = '[email protected]';		# Email address to send emails from. (like [email protected])
$cookiename = 'SMFCookie379';		# Name of the cookie to set for authentication.
########## Database Info ##########
$db_type = 'mysql';
$db_server = 'sql303.byetcluster.com';
$db_name = 'epiz_25449774_346';
$db_user = '25449774_1';
$db_passwd = 'censored';
$ssi_db_user = '';
$ssi_db_passwd = '';
$db_prefix = 'smfuv_';
$db_persist = 0;
$db_error_send = 1;
########## Directories/Files ##########
# Note: These directories do not have to be changed unless you move things.
$boarddir = '/home/vol13_4/epizy.com/epiz_25449774/htdocs';		# The absolute path to the forum's folder. (not just '.'!)
$sourcedir = '/home/vol13_4/epizy.com/epiz_25449774/htdocs/Sources';		# Path to the Sources directory.
$cachedir = '/home/vol13_4/epizy.com/epiz_25449774/htdocs/cache';		# Path to the cache directory.
########## Error-Catching ##########
# Note: You shouldn't touch these settings.
$db_last_error = 0;
# Make sure the paths are correct... at least try to fix them.
if (!file_exists($boarddir) && file_exists(dirname(__FILE__) . '/agreement.txt'))
	$boarddir = dirname(__FILE__);
if (!file_exists($sourcedir) && file_exists($boarddir . '/Sources'))
	$sourcedir = $boarddir . '/Sources';
if (!file_exists($cachedir) && file_exists($boarddir . '/cache'))
	$cachedir = $boarddir . '/cache';
$image_proxy_secret = '77c7a763eab90b8afe1a';
$image_proxy_maxsize = '5190';
$image_proxy_enabled = '0';
$auth_secret = '7b82724d62d946fb6aa2ce3126d8da53f590484272b1bdedec36c7166083aa47';
change $db_user = '25449774_1'; to $db_user = 'epiz_25449774';
not working :frowning:
is it something like the DB servers maybe are down?
The database servers are not down. You can confirm this for yourself by opening phpMyAdmin from your control panel and seeing the contents of your databases.
However, there does not seem to be any content in the database epiz_25449774_346. It doesn’t appear to exist at all, in fact.
Just to be sure: did you make any changes to the settings in Softaculous?
No I didn’t make any change in Softaculous settings. I wanted to but the DB doesn’t connect…
And IDK abt the DB not existing cuz the forum settings.php is as it was, and the database wasn’t deleted so what might be the problem?
If it doesn’t exist, it needs to be created.
But how did it get deleted all by itself? I didn’t do anything to the databases…
