I see that you installed wordpress in subdirectory yourDomain/wp/
if it’s just a new website and you have not worked a lot on it, reinstall is the fastest solution
check the “in Directory” field in Softaculous, it should be empty if you do not want a subdirectory (that WP)
softaculous - if you want to uninstall on the toolbar (up right) the box icon is located (the mouse over that icon will write “all installations”) click it and then How to remove a installation
it’s only unprofessional when you give your address (domain) to someone and he sees the file list instead homePage, It’s also a problem with google (SEO)
what is “slows” your site is a large amount of css files (4 sec)
turn on the console in your browser and visit your site
OxyDac - I moved contents of swaglertools.cf\\htdocs\\wp to swaglertools.cf\\htdocs with FileZilla. I noticed there is another htdocs root folder, is that for private data? I couldn't figure how to move without first changing folder settings in WordPress Admin Panel.
Wow, how can you merge all these css files into one file? Is there a utility, or whats the best way to fix all these ambiguous calls...
Error in parsing value for background. Declaration dropped.
Error in parsing value for padding. Declaration dropped.
I am a little confused how you managed to move wordpress using just FTP (moving the files) because wordpress also uses DB and other things … so it’s best to make uninstall first and then install again. this is also why you had to change the address in wp admin
you’re a programmer (developer) as well as a few of us here and I think it would be best for you to make a static HTML page if you do not need “login stuff”
it would not be difficult for you
and then it’s easier for you to have one CSS
your site is quite simple and there is no need to have so many plugins that carry a large amount of CSS you need to remove unnecessary plugins
what is
this occurs if browser finds specific instructions in CSS selector for other browser.
it not recognize, ignores and reports as a parsing error
unless it is really something wrong with the CSS code
for example
I use Firefox and when he sees
-webkit-linear-gradient
(this is a guide for old versions of chrome, etc.)
firefox thrown an error
the standard is the
background: linear-gradient
in short, that is the legacy of the era while the browsers were non-standardized and this is used if you want to support visitors who have 3 or more years old browsers
Yes, first I edited the .htacess and script installer properties, but global permalinks... were screwball. Undid move. Logged in, Edited Admin WordPress Address (URL)... logged off, moved WP, logged in and edited home page menu permalink... Done!
I installed Asset Cleanup, then removed cause only PRO version functions.
I've already got rid of blog front page, making static. "Static HTML page" you mean move all content to Home Page?
Yes, maybe I don't need comments either, just have copyright notice at bottom of page with contact info.
I use Firefox. You're suggesting: Caniuse command line tool for Firefox?
here you have typo http://swaglertools.cf/audio-playback-control/
sporting = sUporting
why download does not work?
it should not be difficult for you as a developer one thing you have to understand in HTML is the path and scope https://www.w3schools.com/html/html_filepaths.asp
Thanks for pointing out bad download links. Download Monitor plugin needed all the paths corrected after WP dir move.
So if I write a single HTML file, how is it configure in InfinityFree control panel to be launched? Is there an HTML editor, a section for low level writing and testing in InfinityFree?
