******* UPDATE: ALL SERVICES ARE WORKING NOW. *******
Notice to everyone using InfinityFree as their hosting provider:
InfinityFree uses iFastNet servers and it seems incredibly likely that iFastNet has been DDoS’ed, but we are not sure yet. This means that all of their domains are temporarily inaccessible. This includes cPanel.epizy.com, FileManager.ai, and probably also your website.
Before this, the SSL for FileManager.ai had expired, and as soon as that was fixed everything went down. Please refrain from posting about this in this forum. We all know about it, and we are all having the same issues.
FTP should still be working, however, so you can still use that for now. You’ll have to wait until everything is resolved if you are wanting to change any settings in cPanel.
The Admin has tried contacting iFastNet and they are not responding. Unfortunately, nothing can be done about it. We just have to be patient. This issue will hopefully be fixed soon. I hope this clears everything up.
Thank you for posting this informal post. This will most likely also tie into what you had said when we were discussing the SSL issue where after it was resolved, you could not access if.
I stopped using ftpupload.net because it would time out, reject my login, etc.
EDIT: WinSCP “Timeout detected. (control connection) [newline] Connection failed.”
EDIT 2: Never mind, it works but as you said (@anon20706563) it is SO slow.
