I have information at mySQL, column name: message
My first page should print out column data.
Only two 'null’s from code, ‘var_dump’ are presented. Can anybody help me printing out ==> echo $haksik[‘message’];
My Code:
$haksik_result=mysqli_query($connect, “SELECT message FROM haksik”);
If the code is just not writing anything after that, my best guess is that the code may be crashing. Can you please go into the control panel → Alter PHP Config and enable display_errors there? If you refresh the page after that, you may see an error message.
1. This image is the result of code, echo $haksik_result ; 2. Blank is given as the result of code, echo $haksik[“message”]; ,which you can see when you go into my URL now.
