I’ve been using your service for a while without issues but today when I’m trying to update my site by copying a new index.htm (no caps) in the usual folder, the file is indicated as copied and indeed visible… but a few seconds later (like 10 sec) it dissapears !
The size is less than a 1MB.
Is there currently an issue ?
I’ve tried using FTP or using the file management tool and it’s the same result.
Thanks for your help
Hi and welcome to the forum
Under term “usual folder” you mean htdocs ?
Thanks. Yes it was because this html file was near the 1MB limit for this type of file.
It seems this limit is not 1MB but rather around 970kb.
Thanks anyway for your reply.
