I created a subdomain: http://manganlidemircevheri.cevherhazirlama.com
But it does not work. I upload the index.html file to htdocs folder. Not in the subdomain folder. Is it correct? Why is the subdomain not running?
Thanks in advance for your help!
Your subdomain already works, albeit an image you put there is broken
Waooowwww. I cannot see the page. Maybe dns settings are taking time. I will wait and change the image url. Thank you…
There are interesting things. The image url is correct. Buti the image is not visible. The code in the index.html file is here:
What is wrong with the codes?
What is wrong with the source codes?
Nothing is wrong with the code, everything is working. I will repeat…
Clear your cache.
Admin
November 30, 2021, 9:59am
#9
The subdomain page is including images from the base domain. But that’s not going to work here, because our hosting doesn’t support image hotlinking. This means you cannot embed files hosted with us in any other domain, including your own subdomain on the same account.
I changed the image url. But, the opening of the subdomain by browser is not running most of time. I think this will take time. Thanks.
Try clearing your cache. It is working fine for me.
When i try to open the subdomain, always the error page is seen in my browser. Is it normal? How can i fix the problem?
It is probably about my location. Thanks.
system
Closed
December 8, 2021, 8:47am
#15
