If i enter This Page it opens as it is, works fine. But same page is uploaded as index.html but it shows broken page . I have used CSS & JAVAscript in this page. I am using Cloudflare too. I tried by clearing cach and resetting all browser setting.
Right now I have enabled page redirect to /in.html . But index.html is he basic root/directory file . so please fix it. What should i do now ?
Try to put the in.html code AS IS in index.html, becuase the source code in index.html is different.
Then, inform us of the change.
Please do not make twice a topic for the same issue, I have answered in your previous one.
Making a second topic for the same problem won’t help you.
i am sorry, is it possible to delete post? somehow, the problem seemed to be fixed now.
Thanks, I was also thinking the same when I created stupid post How to delete your IF account, but only @Admin can delete posts and I do not know if he will do it.
#IF account,
XD XD
what a topic![]()
Did he delete it?
No, never, although I asked him many times.
I see you’re using Cloudflare on your website. Please note that Cloudflare’s website performance optimization is mostly caching, which means it might take a bit longer for changes to be visible.
But in this case, @ChrisPAR is right: the pages are actually different. They have different HTML codes and link to different CSS files.
**If i enter This Page it opens as it is, works fine. But same page is uploaded as index.html but it shows broken page . I have used CSS & JAVAscript in this page. I am using Cloudflare too. I tried by clearing cach and resetting all browser setting.
Right now I have enabled page redirect to /in.html . But index.html is he basic root/directory file . so please fix it. What should i do now ?**
Also, both topics have been merged now. I’m sorry for the mess.
But next time, please don’t create multiple topics @AshikurRahmanShad . If you’re not sure which category you should create a topic under, then just pick one instead of posting the same message twice.
