I have updated my index.html file for http://news.ruxm.ga/ and it is still the old one, but if i go to http://news.ruxm.ga/index.html/ it is the new one, can someone help me?
The link above doesnt work for some reason, try this one for the new design http://news.ruxm.ga/index.html
both are same. so itβs updated. please try to clear your cache
Again, it sounds a lot like browser cache. You can try to open the website in private browsing mode and see if you get the same issue that way.
You can use meta to not store cache data, so whenever you update the website files, it will change immediately, or you can use php echo ββ to show your code whenever you update your code
the PHP trick worked for me.
my web-app also experienced this type of error.
please wait a moment to change things,
