Infinityfree acme ssl not pointing to the right destination in my site. That would be the problem, i did everything as described in the tutorial. Why?
Which domain?
osztalyszerver.ml
That domain is not in the SSL Certificates list. If you want to create an SSL certificate for it, you’ll have to add the domain to the domains list in the SSL Certificates panel and follow the instructions to get the certificate.
