its usage is just 33% OF THE AMOUNT availabe. Yet it shows error of innodes full ???
You seem to have a lot of folders and files,try to delete some.
More specifically
The inode counter has been claimed to be buggy; but it doesn’t update the inodes live, only the percentage is live.
I think you’re misreading the numbers. The first number is your current usage, the second one is the limit.
The limit is 30,000. Your usage is at 106,328. That’s three and a half times the limit.
So I do agree the counter is off, because it should have kicked in MUCH earlier than this.
