I tried to install some installations, but I could not. It writes could not write Configuration File config.php.
@Goranko, Hello, could you be more specific? What exactly are you trying to do? Does the error show up when you have filled all the fields in Softaculous and press Install, or the error shows up when you go to your installation’s website? Make sure that you have filled out all the Softaculous installation form fields correctly, including your website’s email that exists. Also please tell us, which web software are you trying to install?
It was happened when I pressed Install. I was trying to install many installations, I could not install.
@Goranko Please give me your website adress and links of your directories with all your installations, so i can take a look at it!
Everything is OK now.
