Is a mysqli query cosidered a hit
Hi guys, so I’m on the free plan and I read this post about hits, but I still have this question.
if I connect to a server and a database using php as usual and do “SELECT * from tabe”, is this a hit or not ?
and can I do it like every 20 to 30 seconds or maybe less, just making some sort of a crazy testing project :slight_smile:
thanks
Every time you load a file, it counts as a hit.
A MySQL Query is not a file, so it does not count as a hit.
However, if you are reloading a PHP script to run that command, each reload counts as a hit
Thank you so much. that makes sense
