Is it possible to set up TLS and how do I do it
CloudFlare has some options for TLS. Register with Cloudflare and then go to dash.cloudflare.com. Click on SSL/TLS and then create an SSL certificate. After this, you will see some TLS options like the following:
You will also get to see TLS statistics like here:
I hope this helped.
Our control panel has an SSL/TLS menu and our client area has a Free SSL Certificates menu. So yes, you can get and install free TLS on our hosting.
Thanks, ur a hero
Thanks
