Is this forum made by BBPress?
Is this forum made by BBPress? Because I need a forum like this Thanks
No, it’s Discourse
Can that be used on WordPress?
This forum uses discourse, to use it you’ve to install it on your own server or vps as it requires ruby and high server power usage. For a cheaper alternative you’ve to use flarum but you’ve to prepare and install it on your own device before using on any free hosting if you don’t want to cost too much.
No, because Discourse is a standalone forum platform
Why not use other available forum plugins for WordPress?
Because you don’t have the moderator plugin with it
Then use any other forum apps which cannot be used on WordPress. Finding such forum WordPress plugins would be costly
Try flarum, there is even free flarum hosting at freeflarum.com
