When I am trying to update my css file at ftp.its showing updated contents in css file but on the site the webpage is working only with old css file content.
Even after deleting and reuploading both html and css file the issue pursues.
I solved it temporarly by adding css content inside html file with style tag but how to solve this permanently?
Adding to what Frank419 noted, please do not ping people as there are plenty of us here that can help you. However, this is free support so you must be patient.
Are you sure that you have uploaded the file with the correct filename/path? Is your code loading the correct file?
And maybe, upgrade your os/browser. Z-indexing might not be working on old softwares.
False. InfinityFree does not modify the website frontend unless there is something which violates the ToS. the telegram API is blocked but linking to your telegram ID is not.
This is about making external websites making embed of your website, nothing related to the issue with clicking buttons.
I can click on the links and it works fine for me. If anything, you can add the target="_blank" attribute to your <a> tags to see if they work while opening in a new tab.
The style.css file is missing but it should be irrelevant to what you face into.
Maybe the OP expects that link to be opened in the telegram app (judging by the screenshot from the mobile phone)
and if so, then the problem is in his device/app
