What I’m seeing is:
1… I activated cloudflare from c panel and its been in 72 hours but still i not getting the https when i access my page. Why is that.
I’m using this software:
2…If i try to configure cloudflare from directly there webpage then since i don’t have the server ip for my web page as im using free package from infinity so how i will create cname record to point my domain to this server etc.
Additional information:
3…And since its free hosting… I AM UNABLE TO INSTALL ANY PLUGIN ON MY PAGE ITS SAYS ‘’ UPDATE FAILED’'. HOW TO SOLVE IT
I can access the webpage via HTTPS, but you also need to fix the URLs to point to HTTPS version of those, and you can do so by following this guide. For you it’s because of SSL and DNS caching issues.
You can find the IP address to use on the guide below:
if you want to use Cloudflare directly through their dashboard.
You can install plugins via a FTP client. You can find the instructions here.
So nice to hear some great tips from you ERGASTOLATOR1.
Will surely will work on them and hopefully all is being resolved.
Thanks for always supporting
