Jetpack curl error 60: ssl certificate problem: unable to get local issuer certificate jetpack
epiz_26017867
jetpack curl error 60: ssl certificate problem: unable to get local issuer certificate jetpack
After installing WordPress and installing JetPack, this problem occurs ,
I activated my SSL certificate and it is working properly
What is your website link and where did you get your SSL? It must be a problem with the SSL.
This is because it cannot verify your server’s SSL certificate, as its chain is incomplete.
The problem is that OpenSSL doesn’t recognize your certificate’s Certificate Authority’s (CA) certificate
Unfortunately, Chain & root certificates are only available to premium plan.
  • According to Wordpress forum & knowledgebase
EDIT: YOU CAN STILL USE CLOUDFLARE, if you want. CloudFlare is the only possible solution to this problem
So yeah, I suggest you to use the Infinityfree tool for free SSL and to work fine!
https://app.infinityfree.net/acmeDomains
or the cloudfare.
