Jetpack is not working on wordpress
Jetpack is not working on wordpress. It says “Your installation of Jetpack is incomplete. If you installed Jetpack from GitHub, please refer to this document to set up your development environment” what should I do now ?
Did you check any of the many other topics about Jetpack on our forum for possible explanations already?
https://forum.infinityfree.com/search?q=jetpack
Yes, I checked but couldn’t find this issue.
Deactivate and delete Jetpack from the plugins page. Then, download the zip file of Jetpack from the plugin’s official wordpress site, go to “Add Plugin”, and upload the zip file. It will correctly install Jetpack.
