Hi, I am trying to mimic this simple example: JS Bin - Collaborative JavaScript Debugging where it uses a static HTML for the code, CSS and javascript. When I do on an internal web server it works. When I do the same here I do not see the pull down menus or search box. Does anyone know why? I tried using the files locally instead of pointing to the nightly builds but can’t get it to work.
Thanks,
