Js and json not working
Website URL
testhsk.000.pe
no error msg
I made a sample website which fetches data from json and then js file makes card for those info, in vs code live server its working, I have no idea how to make it work on hosting
I see no problems on your site.
Can you describe your problem clearer?
Sorry for the late reply, and thanks for your kind reply
What i was doing wrong was the path of json file was/data.json
I looked it up 3-4 hours of reading and testing and then later i added the url and path then it worked just fine.
