no errors
the first free domain I selected when signing up, is listed in Vpanel under Addon Domains. a message says:
Note: You must set your domains name servers to the following before adding the domain to this system:
ns1:epizy:com
ns2:epizy:com
the support page for domains and DNS says:
“The nameservers of your domain name are a setting at your domain registrar to allow you to host a domain name with a different provider. So you need to change these settings at the site where you bought your domain name.”
but it’s not a seperately registered domain, it’s hosted here.
it does work. uploaded a test index.html and it loads. what I am concerned with is the location of the folders on the server (seen with FTP). that domain doesn’t have its own folder like the other two subdomains.
and those other 2 subdomains, created in Vpanel/Subdomains, are listed under subdomains. they don’t have that message. they do have their own folders on the server.
why isn’t the first subdomain in its own folder on the server? shouldn’t it be that way?
what happens if I rename or remove the first subdomain, does that break the functionality of the other 2 free subdomains, or delete them, or how does that work
