Prunity
September 11, 2021, 4:39am
#1
Let’s Encrypt & OpenGraph | Not Sub Domain - The certificate is not trusted in all web browsers.
Upon checking the SSL via SSL Checker (sslshopper.com) . It says that:
The certificate is not trusted in all web browsers. You may need to install an Intermediate/chain certificate to link it to a trusted root certificate. Learn more about this error . The fastest way to fix this problem is to contact your SSL provider.
When trying to use OpenGraph, Facebook trying to throw this error:
SSL Error: Can’t validate SSL Certificate. Either it is self-signed (which will cause browser warnings) or it is invalid.
Curl Error: Curl error: 60 (SSL_CACERT)
That’s why I check my SSL information to see the problem, because my OG is not working to non sub-domain but back then the subdomain with ssl works before.
@Prunity , you can safely ignore it. Read this:
If you have installed an SSL certificate on InfinityFree, you may want to use an SSL Checker tool to verify your SSL certificate was installed correctly. However, when doing so, you see an error like this:
The certificate is not trusted in all web browsers. You may need to install an Intermediate/chain certificate to link it to a trusted root certificate. Learn more about this error. The fastest way to fix this problem is to contact your SSL provider.
What does this warning mean for your si…
Prunity
September 11, 2021, 4:57am
#3
But I wonder why my OpenGraph doesn’t work.
Inferred Property
The ‘og:image’ property should be explicitly provided, even if a value can be inferred from other tags.
Missing Properties
The following required properties are missing: og:url, og:type, og:title, og:image, og:description, fb:app_id
Prunity
September 11, 2021, 4:58am
#4
But I already have this settings already like:
I used https://www.opengraph.xyz to generate everything
did you install the certificate? which one did you choose? from where? hope you didn’t choose the self-signed!
In order to get a padlock in the address bar in your website, you need to install an SSL certificate on your account. This article describes how to do that.
Installing an SSL certificate
The first step to install an SSL certificate is of course to get the SSL certificate. You will need to get this SSL certificate at a certificate vendor of your choice. InfinityFree also provides free SSL certificates from the client area , but you are free to use any other recognized SSL vendor too.
If you al…
Prunity
September 11, 2021, 5:13am
#6
Prunity
September 11, 2021, 5:19am
#7
I’m trying to re-create a new one today.
Prunity
September 11, 2021, 5:41am
#10
I am now using Free SSL Certificates - InfinityFree Let’s Encrypt Provider and still the same output. OpenGraph not working
Prunity
September 11, 2021, 7:02am
#12
Yes from Free Certificates every thing is fine except for the OpenGraph
Prunity
September 11, 2021, 7:03am
#13
This is the output in facebook debug
Prunity
September 11, 2021, 7:04am
#14
and also here’s the output of opengraph.xyz
Admin
September 11, 2021, 12:45pm
#16
This security system will block almost any tool that wants to generate OpenGraph tags (and most other automated access):
InfinityFree is a website hosting service. That means that the hosting accounts we provided are intended for hosting websites. Websites contains pages which are accessed through web browsers. InfinityFree is not intended to be used for file sharing, API hosting, database hosting or background tasks/tools.
To help enforce this, the free hosting enforces a security system which makes sure that anyone trying to access your website is using a normal web browser. This is done by checking whether the…
Try using Cloudflare. It will get around that restriction. You can also use it for SSL
Hello,
I will show you how to easily set up Cloudflare, Edit Records, and Troubleshoot with images!
PLEASE READ BEFORE STARTING!!!
DO NOT USE THE CONTROL PANNEL INTEGRATION (It can break your site!)
Cloudflare CANNOT be used on free subdomains from InfinityFree
You CAN use Cloudflare on Custom Domains (yoursite.com ) and with Custom Sub-Domains (subdomain.yoursite.com )
------- Set-Up Cloudflare -------
Go to Dash.Cloudflare.com and create a new account (Or log in to your existing one)
A…
system
Closed
September 18, 2021, 1:31pm
#18
