Is it possible to use CloudFlare as my dns hosting, but disable CF’s SSL (Universal) and use Lets Encrypt SSL that is provided by InfinityFree?
Additional information: I have already setup the SSL on InfinityFree successfully. I just want to use Let’s Encrypt instead of using the Universal SSL that CF is providing. Thanks!
If you want Let’s Encrypt. You need to upgrade to a premium plan.
I believe custom edge certificates in Cloudflare is a feature only available to Business or even Enterprise clients. If you pay anything less than hundreds of even thousands of dollars per month, you’re going to be stuck with the certificates provided by Cloudflare.
